Diversas preguntas; ¿Qué emisora me compro?, ¿Fibra? ¿motor?
Hola a todos.
Estoy haciendo mi primer barco RC, el PHANTOM de Billing Boats.
El caso es que me quiero comprar una emisora no muy cara, pero fiable, de 4 canales (por si las moscas; veleros etc)
Me gustaría algo que no tuviera cristales (2,4 GZ) ni interferencias, (creo que hay unas ahora que se "casan" indisolublemente con el receptor y sólo atienden las órdenes de su "amo") y que pudiera encontrar repuestos y sobre todo receptores compatibles a buen precio, para no andar quitandolos y poniendolos en futuros barcos
Había pensado en ésta
Algún consejo o sugerencia
¿Habéis comprado en Hobbyking? ¿Alguna tienda en Madrid?
Muchas gracias por anticipado
Radio Link 2.4Ghz 4 Channel RC System
Supplied with 4 Channel Transmitter and 7 Channel Receiver
Description:
For use with Remote control Cars, Boats and Aircraft along with other uses.
No more need for crystals, just bind the handset to the receiver once and its done, just turn on and go! The RadioLink transmitter and receiver feature Advanced 2.4GHz control. 2.4GHz is a worldwide frequency that has many applications and uses. This technology is very suited to enhance safe flying through the model and hobby industry. 2.4Ghz technology creates the advantage for a ‘bound’ relationship between the Transmitter and Receiver. The setting up of this relationship is known as ‘binding’. In a ‘bound’ transmitter/receiver relationship the receiver is exclusively bound to your transmitter and can only respond to signals received from your transmitter. It will not respond or receive signals from any other device or transmitter transmitting on the 2.4GHz frequency band. Binding is done at the factory. Once a transmitter is bound to it’s receiver, re-binding of transmitter and receiver is not normally required.
Specification:
Range: 200 m
Transmitter Channels: 4
Receiver Channel: 7
Additonal Receivers available at only £15.00!
Última edición por Llaut Mallorquin el Mié May 14, 2014 9:24 am, editado 1 vez en total.
jomaal88
Re: ¿Qué emisora me compro?
Mensaje por jomaal88 »
Yo tengo esta y va muy bien
http://www.hobbyking.com/hobbyking/stor ... ware_.html" onclick="window.open(this.href);return false;
En construcción: ....
Mi web: pincha aquí
jomaal88 escribió:Yo tengo esta y va muy bien
Gracias jomaal88, había pensadoen esa pero resulta que no hay recetores sueltos a la venta y querría comprar por lo menos un par de ellos.
¿Sabes si hay algún receptor compatible con esa emisora a un precio razonable?.
Es lo que me hace dudar, en cambio para la FUTABA sí que hay receptores.
jomaal88
http://www.hobbyking.com/hobbyking/stor ... r_V2_.html" onclick="window.open(this.href);return false;
solo una aclaracion el precio no es en euros si no que es en dolares
Mi web: pincha aquí
jomaal88 escribió:http://www.hobbyking.com/hobbyking/stor ... r_V2_.html
Muchas gracias jomaal88.
Me lo acabo de comprar :D :D :D :D
Un saludo muy cordial
He descubierto ya el hilo de los variadores, gracias.
josechu
Mensaje por josechu »
Hola Llaut
disculpame, que no te halla podido responder antes,
si al final te has comprado la Turnigy_9X_2_4GHz_8Ch
enhora buena, pues esa es la que yo te hubiese recomendado.
yo, es esa la que tengo y estoy muy contento con ella.
saludos a todos.
josechu escribió:Hola Llaut
saludos a todos.
Gracias por tu respuesta, Josechu.
He entrado temblando : al ver que me respondías, pensando que me recomendabas otra.
Pues nada, estoy contento con la compra y con vuestros comentarios(todavía no me ha llegado).
Gracias a jomaal88 y a tí.
Ya os comentaré.
Un saludo cordial
jomaal88
Es la misma que tiene Araola para que vayas abriendo boca te pongo un vídeo en youtube en el cual muestra como enlazar la emisora con el receptor
saludos cordiales
Mi web: pincha aquí
Valiosa información, jomaal88, sobre todo para los novatos como yo. :D
Muchas gracias de nuevo y un saludo cordial.
josechu
hola Llaut
bien, hombre no tengas nunca dudas en preguntar algo
el foro está para eso,
y si uno se equivoca, pues no pasa nada.
el compañero y amigo Jomaal, te ha contestado muy bien, perfecto diria yo.
pero lo que suele ocurrir muchas veces, es que esto de la emisora va en gustos.
a mi, me consta, que tanto Araola, como yo desde luego nos gusta mucho esta emisora y la solemos recomendar a nuestros amigos, y eso que no tenemos comisión.
pero cuando un producto, es bueno.
y mas por su precio, es recomendable comentarlo,
ahora solo queda que la tuya no traiga ningún defecto y nos dejen por mentirosos,
bueno que la disfrutes durante muchos años
josechu escribió:hola Llaut
Hola Josechu.
Es muy reconfortante la ayuda que nos prestáis a los que empezamos en este mundillo del RC :D
La verdad es que hay miles de productos y uno se lía un poco.
Pues nada, muchas gracias y ya os preguntaré alguna cosilla de la que dude.
Saludos Josechu.
Bueno, aquí va otra pregunta.
Estoy haciendo una lancha clásica sobre un kit de Billing Boats.
Esta la PHANTOM
https://www.youtube.com/watch?v=3btGs-Z8TjI
Me gustaría que tuviera las prestaciones de la del vídeo.
El "tuneo" que le hizo el modelista del vídeo es éste (Traduzco , copio y pego).
TUNEO PARA PHANTOM BILLING BOATS
Peso 61 gr.
Eje: 2,3 x 14 mm / 3,17 x 14 mm
Tamaño: Ø28 x 34mm
RPM / V 3200
Voltaje de funcionamiento: 6-11 voltios
Funcionamiento Amp. 9-18
Potencia máxima durante 15 segundos. 24 Amp
Yo creo que está diseñado para su uso en un helicóptero eléctrico.
La batería de mi favorita es una 1700mAh 3S LiPo
También sustituí el puntal para un 0,8 pitch (hélice) Graupner 32.5mm
La pregunta es:
Por lo visto lleva un brushless y yo dispongo de varios motores de escobillas.
Para esas revoluciones por minuto ¿Qué motor de escobillas le pongo para que navegue como en el vídeo?
Billing da como opción un 340, pero creo que es algo corto :roll: :roll: :roll: :roll:
La lancha mide 70 cm de eslora; es ésta
Un saludo cordial
josechu
hufffffff
eso me pasa por querer ayudar,
jejejeje.
bueno amigo, según lo veo si quieres poner un motor de escobillas, lo primero será pensar en la batería y el variador,
veo que me hablas de lipo,
bien a ver si algún otro compañero nos aconseja algo con lo que podamos ir comenzando.
sigo atento al hilo.
Hola Josechu.
Si me pongo pesado, pido disculpas. :(
No es mi intención repetir las preguntas que ya se han hecho en...¿dónde? (el foro está un poco disperso en estas cosas).
He intentado leer todo lo posible sobre RC, hay un enorme número de temas y no lo he conseguido.
Estaría bien abrir una serie de hilos específicos, donde se pudieran aclarar dudas, sin preguntar una y otra vez lo mismo.
Por ejemplo:
MOTORES.
VARIADORES (compatibilidad)
EMISORAS
SERVOS
BATERIAS
FIBRA (la gente habla de "velo" pero igual es el de la Macarena, falta densidad, peso etc)
RESINA (en esto hay un poco más de claridad)
PINTURAS (menos que en lo anterior)
PEGAMENTOS para RC. (cuales son los adecuados para navegar)
TIENDAS (aunque sea publicidad, creo que sería INTERESANTÍSIMO CONONCER LINKS DE BUENAS TIENDAS PARA RC NAVAL)
Leo una y otra vez los paso a paso y sólo en contadas ocasiones, alguien habla con claridad del tipo de configuración de su barco (casi siempre se dejan algo).
Y en las tiendas de internet lo mismo, enorme cantidad de productos y se da por supuesto que el que compra, sabe de todo.
Sólo en contadas tiendas (extrajeras por supuesto y en inglés) dan consejos para la configuración del barco (y la mayoría de las veces, te remiten a sus productos.
La información de los motores, por ejemplo, en el producto físico es nula o escasísima (tengo algunos motores que no sé lo que son ni que potencia tienen)
En tendas "físicas" la mayoría no tienen ni pajolera idea (al menos las que yo conozco) y las especializadas suelen ser para coches o aviones
Además es un poco de caradura, interrogar al dependiente y hacerle perder el tiempo y luego marcharte sin comprar nada
Soy novato total en RC y llevo meses intentando informarme y leo muy diversas opiniones; al final me doy cuenta que sólo funciona el boca a boca, o equivocarse onerosamente.
Mi sugerencia creo que podría ser útil, sobre todo para ahorrar tiempo.
De todas formas, gracias a tí y al resto de los foreros que con respuestas particulares, nos aclaráis algo las ideas a los novatos.
Si me he pasado , pido disculpas, pero lo digo como lo siento.
Saludos cordiales
